Installation monitor not recording entries
I have just monitored two installations of programs, and both times UT states that no entries were made. I know there are hundreds of entries in the registry. I checked the saved logs and it has only recorded files and folders. What am I missing?
Re: Installation monitor not recording entries
Hello, please tell us
1. Your Windows version and whether it's 32 or 64-bit
2. Which installations did you test? Is there a way to download them to check the issue?
