Uninstall Tool 3.0 Beta
eil
Re: Uninstall Tool 3.0 Preview Release
Post by eil »
nice behaviour! :smile:
Trashe1
Post by Trashe1 »
ok
i am waiting new version
Trashe1
Post by Trashe1 »
how hard it is to wait
eil
Post by eil »
if we can help somehow with that, just say ;)
Trashe1
Post by Trashe1 »
happy to help:)
The best help will be testing of Install Tracker. Thanks for being patient :smile:
Windows Explorer extension and setup will be available in beta
http://www.crystalidea.com/install-trac ... on-monitor
Some news: a couple of days are left, some issues were fixed:
* Wizard: fixed scanning of X64 entries (related to MSI installed products)
* Wizard: fixed check/uncheck of items in a tree control
* Wizard: fixed partial removal of items selected in a tree control
eil
Post by eil »
already saving 2 installs with system integration, to test it right a way :smile:
We released last preview today: 3.0.0.3170
Trashe1
Post by Trashe1 »
thanks for the new thing. I just x64 windows will test
Trashe1
Post by Trashe1 »
now launched version 2.9.7 and saw that I had installed the 73 program at 2.11 GB
and launched version 3.0 of the saw that I had found 66 programs at 1.57 GB
not very clear why. Put my picture below
What is the program version 3.0 does not see :-(
additional office files export
file format in version 2.9.7 is much easier to read
http://depositfiles.com/files/dwuete9rx
Uninstall Tool 3 uses better algorithms to determine Apps/System/Hidden categories.
Trashe1
Post by Trashe1 »
Steven wrote:Uninstall Tool 3 uses better algorithms to determine Apps/System/Hidden categories.
Now everything is clear
and export the file format will change?
We'll add additional HTML columns in next versions.
Re: Uninstall Tool 3.0 Beta
Hi all!
First beta is available for download!
For translators: translation can be done now using the XML files inside the beta package.
Trashe1
Post by Trashe1 »
took the translation of 3.0, and immediately found a bug
I decided to install Vlc player using the "install trace" was the installation log but the picture shows that the installed software 0 :(
18:58:40 Уст. значения HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VLC media player\[@]DisplayName
18:58:40 Уст. значения HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VLC media player\[@]UninstallString
18:58:40 Уст. значения HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VLC media player\[@]InstallLocation
18:58:40 Уст. значения HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VLC media player\[@]DisplayIcon
18:58:40 Уст. значения HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VLC media player\[@]DisplayVersion
18:58:40 Уст. значения HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VLC media player\[@]URLInfoAbout
18:58:40 Уст. значения HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VLC media player\[@]Publisher
18:58:40 Уст. значения HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VLC media player\[@]VersionMajor
18:58:40 Уст. значения HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VLC media player\[@]VersionMinor
18:58:40 Уст. значения HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\VideoLAN\VLC\[@]Language
18:58:42 Создан процесс C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
18:58:42 Процесс завершен D:\проги\vlc-1.1.11-win32.exe
18:58:43 Создан файл C:\Program Files (x86)\VideoLAN\VLC\plugins\plugins-04041e-3e8.dat.2532
18:58:48 Процесс завершен C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
18:58:48 Все процессы завершены
18:58:48 Инсталляция завершена
18:58:48 Сервис остановлен
18:58:48 Анализ инсталляции, пожалуйста, подождите...
18:58:49 Обнаружено установленных программ: 0
Thank you, will fix in next build.
Not a bug, just a translation misspelling
Trashe1
Post by Trashe1 »
I even found a little bit. see the previous post
I'm sorry that in Russian. I can repeat in english
About VLC: If a previous version of this program is already installed, you should remove it first before installing a newer version
Trashe1
Post by Trashe1 »
Steven wrote:About VLC: If a previous version of this program is already installed, you should remove it first before installing a newer version
I did so :-)
Locked
