Uninstall Tool 3.0 Beta
Re: Uninstall Tool 3.0 Beta
eil
Please give us the MD of it.
Update: Please try build 5204
eil
Post by eil »
md5= 0a9760f7fa09ac0e5a41c366eb341dd4
edit: damn, i swear i saw you questioning about md5 with link.. :shock:
Ok, thanks! This is an old one, please update to 5204
Update: sorry for editing. Fixed.
eil
Post by eil »
5204 = it works! :smile:
yet, it would be good if context-trace-installed programs were highlighted too at next UT launch(same as programs that were installed ordinary).
eil
Yes, that's a bug. Will fix it in next build. Thank you.
Trashe1
Post by Trashe1 »
a small addition on the "insrtall & Trace" on the selection screen that says you can select files of type *. exe and *. msi but there is the file format *. msu
the example below
Trashe1
Can you try renaming it to .msi, does it work?
Trashe1
Post by Trashe1 »
rename help. but it seems to me that this is not the best option
installation files are not so much uh. and if the installer will have a *. bat
and one more little question. and the translation will help? and then the program itself is in Russian. Help in English :-(
Well, after some research we found out that .msu files are installed with a special utility wusa.exe. We'll add support of such files in future. Thank you
Help file is available in English language only. At least its translation is not planned yet.
Hi, dear users!
What do you all think
- Is current Install Tracker useful/functional/interesting?
- Is beta version ready to become final?
Trashe1
Post by Trashe1 »
"install & trace" the desired function. except that all comments will be and make an official release
Rafel
Post by Rafel »
Install tracker is very interesting and useful. I like to see all changes in my system.
I can try beta versions because is my work PC. I'm waiting final release for translating to catalan.
Translation can be already made. English.xml will not change for the final release.
Rafel
Post by Rafel »
Thanks a lot.
Trashe1
Post by Trashe1 »
and completed the export file?
No new features will be added for the 3.0 final, it's ready.
Rafel
Post by Rafel »
UT can't trace installation of Mozilla Thunderbird 8.0.
Log:
20:54:12 Starting Install Tracker service...
20:54:12 Service version is: 0x103
20:54:12 Starting Thunderbird Setup 8.0.exe...
20:54:13 Error: Cannot start the setup process (error 193)
20:54:18 Error: Failed to stop the tracking service
20:54:18 Analyzing installation, please wait...
20:54:18 0 installation entries detected
Rafel
Are you trying to run a 64bit process on a x86 system?
Rafel
Post by Rafel »
Nope.
My system is Win 7 Ultimate x64(legit, not cracked or something else).
If you want i can test it in my other PC, with XP Pro sp3 x86
Rafel
Yes please. And the download link to this setup is highly appreciated as well
Update: Some info
Locked
