Dustyn
Feature request: resume tracing after reboot
08 Sep 2014, 22:17
Hello :smile:
I wanted to check if a feature exists that allows an installation of an application to be traced, even when the computer must be restarted when requested by the installer package to complete an installation?
Thank you,
Dustyn
PS: Currently using Revo Uninstall Pro and it does not support tracing during an installation that wants a reboot.
Re: Installing/Tracing Application: REBOOT REQUEST
08 Sep 2014, 22:26
hi, Dustyn
Updated
That's a nice feature request. I'm putting this to the TODO list. Not sure of implementation at the moment, but it will be done I believe. Though there's NO 100% sure way to detect if an installation will continue after reboot, so I think it will work in most of cases but not all of them.
What can be done now: Append traced data manually after reboot (will work for some cases)
Dustyn
Re: Feature request: resume tracing after reboot
08 Sep 2014, 22:33
Ahh, okay thanks for the info. :smile:
Appending traced data manually after a reboot is an interesting addition.
08 Sep 2014, 22:33
I've updated my post.
Dustyn
08 Sep 2014, 22:35
That answer indeed changed! :D
I like it, thank you kindly.
adamlogan
09 May 2017, 07:39
+1 for this feature request. The append feature and portable license are what compelled me to start using Uninstall Tool vs competing products.
Surviving reboot when uninstalling would be a stellar feature as today's software becomes more invasive installing services and whatnot.
09 May 2017, 19:53
Thanks for the update! Will look into this once again.
