Monitoring after reboot? Removing toolbars etc.?
micrei
Post by micrei »
I have the following questions about the paid version of the Uninstall Tool:
1) Can it monitor the installation of programs that require a reboot during the installation?
2) Can it remove browser toolbars and plugins (e.g. after I installed a program loaded with adware)?
Michael
Re: Monitoring after reboot? Removing toolbars etc.?
Hello micrei,
1) This issue is still not implemented. You have to stop Install Tracker, then reboot, then continue by appending data. We're looking for a way to simplify this process.
2) Uninstall Wizard is able to remove Internet Explorer plugins if the're a part of the app installation. To remove all toolbars & plugins one has to use Install Tracker to make sure everything will be reverted later.
