Uninstall Tool 3.5.2 beta
27 Oct 2016, 10:11
Install Tracker now supports .msp files to append traced data
Uninstall Tool now remembers (apps list) sorting parameters between its launches
Uninstall Wizard leftovers scan speed is increased in 3-5 times (really noticable, specially on Windows 10)
Size calculation algorithm now includes data folders (e.g. in AppData, MyDocuments and others)
Fixed incorrect detection of apps as recent
Fixed Install Tracker working in Windows 10 with Secure Boot turned on in BIOS
Fixed calculating of apps installation date in Windows 10
Fixed crash on old CPUs without SSE2 on Windows XP 32-bit
New, more safe license checking scheme on 32-bit Windows
Minor fixes
Download
27 Oct 2016, 19:59
Build 5531 fixes blinking of icons
pcorot
28 Oct 2016, 08:59
Or can download the 5531 build?
Thank you
28 Oct 2016, 09:12
The link is the same.
17 Nov 2016, 22:22
Build 5540:
fixed driver working in Windows 10 with Secure Boot turned on in BIOS
fixed calculating of apps installation dates
18 Nov 2016, 08:56
Build 5541:
improved calculating of apps installation dates on Windows < 10
19 Nov 2016, 16:45
Build 5546
- the app now remembers last list sorting criteria
- increased list item height from 32 to 40px for better readability. Experimental, please give us some feedback.
21 Nov 2016, 16:15
Build 5550
- Uninstall Wizard leftovers scan speed is increased in 3-5 times (really noticable, specially on Windows 10)
- Size calculation algorithm now includes data folders (e.g. in AppData, MyDocuments and others)
23 Nov 2016, 08:45
Build 5551:
Fixed crash on some Windows 10 systems, we're sorry for the inconvenience.
Re: Uninstall Tool 3.5.2 beta
12 Jan 2017, 00:57
Build 5552:
Fixed detection of install date of some programs
