cyclova
Portable License question
25 Jun 2017, 22:46
If I buy the portable version of Uninstall Tool, can you say more about the installation restrictions?  Can it exist as only one installation on a single flash drive, and used only from that flash drive?  Can I keep it on two flash drives?  Can I install it in on my PC as well?  Please explain what a portable license permits, and thank you.
Re: Portable License question
26 Jun 2017, 19:28
You can install it on 1 home PC and use single USB flash drive with portable version on other computers.
cyclova
04 Jul 2017, 21:03
Hi Steven, I do have another question before registering.  Does Uninstall Tool need to contact your servers after initial installation?  In my case, I minimize connection to the internet as much as possible, and do most of my work offline.  I also firewall as much as possible, and update software selectively instead of automatically in the background.  I would appreciate any comments, thank you again.
05 Jul 2017, 14:20
Hi again,
No, Internet connection is not required.
