Bea
Bit Defender
15 Sep 2017, 13:03
I've tried to remove this programme, but Uninstall Tool still leaves bits behind which prevents 'Windows Defender' from working.
Please help.
I shall have to install the programme again in order to gain some protection on my computer.
Re: Bit Defender
16 Sep 2017, 21:46
I recommend reinstalling BitDefender with Install Tracker function:
https://www.crystalidea.com/uninstall-t ... on-monitor
Bea
Re: Bit Defender
18 Sep 2017, 06:05
Thankyou, I tried that, but there are still 'bits' left behind.
Re: Bit Defender
18 Sep 2017, 12:32
Anti-virus products can be sometimes tricky to get rid of completely. They use some undocumented ways to remain in a system.
Did you try their uninstall utility?
https://www.bitdefender.com/uninstall/
Bea
Re: Bit Defender
20 Sep 2017, 15:39
Yes I have.  Thankyou for your assist.  I think I'll have to wait until my computer warrants calling out the Mr fixit guy.
