ma_t14
Mass Uninstallation
25 Jan 2010, 14:46
Hi, this is my first post here. First of all I would like to thank you for this faboulous piecce of software. It's speed and ease of use cannot be rivaled by any other tool regardless of price. :D
Now here's my request. Is it possible in the next release of Uninstall Tool (v3) to include the feature to make multiple uninstallations at once like in MyUninstall by Nirsoft? I think this is the only major feature besides an installation monitor missing to make Uninstall Tool perfect.
Re: (reuest) Mass Uninstallation
25 Jan 2010, 16:21
Thank you for your kind words. Yes, Installation Monitor will be in Uninstall Tool in the nearest major updates.
The program you mentioned is not able to uninstall several programs in one session (just checked). It's certainly possible to organize running of several uninstall processes at the same time. But is user able to interact simultaneously with their windows (pressing 'Next' buttons, choosing other uninstallation options)? It's not convenient. And about Uninstall Wizard, it should probably wait until all uninstallations are finished... :%)
Well, currently CrystalIDEA thinks that the most effective way to remove software is to concentrate on removing a certain program :smile:
Re: Mass Uninstallation
20 May 2012, 15:39
Duplicate, please refer to this topic
