Window size and position
I would like to find out why doesn't Uninstall Tool save it's size and position? It feels like it saves the size and position during register procedure and uses it after.
Is it possible to make Uninstall Tool startup always maximized?
Re: Window size and position
MrT
The program restores last window position and maximized state for years. You should check if it can save its settings (some system problem?)
Steven, where does it keep that settings?
3.x keeps it at
C:\Documents and Settings\$USER$\Application Data\CrystalIdea Software\Uninstall Tool\preferences.xml (XP)
C:\Users...- on Vista/7
I have this:
I've changed to this
and now it starts maximized.
<Window7_Theme type="1">1</Window7_Theme>
<Window_Maximized type="1">1</Window_Maximized>
<Window_nHeight type="1">0</Window_nHeight>
<Window_nWidth type="1">0</Window_nWidth>
<Window_x type="1">0</Window_x>
<Window_y type="1">0</Window_y>
<Window_nHeight type="1">1</Window_nHeight>
<Window_nWidth type="1">1</Window_nWidth>
MrT
I'll look into the problem now. Using latest version?
Steven, yes. I've bought SSD, reinstalled Windows with AHCI mode enabled and downloaded the newest version. Windows user is in Administrators group, UAC's disabled.
I've entered registration when window wasn't maximized, if it helps.
MrT
Thank you for the report. I recommend removing the preferences file and run the program again. Does it save the size/state after that?
Steven, no, after removing the file it startups not maximized again.
MrT
but if you maximize it, and close. Does it appear maximized next time?
Steven, no. I've tried different variants from clicking on other tabs to changings some options in preferences menu - it appears not maximized again.
MrT
Can you please post the preferences.xml file once again?
BTW. Which Windows are you running on?
Steven, Windows 7 x64 Corporate.
This is my current file, after deletion I've again changed two dights:
<?xml version="1.0" encoding="UTF-8" ?>
- <PortableProgramData version="1">
<AppList_HighlightRecent type="1">1</AppList_HighlightRecent>
<AppList_HighlightX64 type="1">1</AppList_HighlightX64>
<AppList_IconSize type="1">0</AppList_IconSize>
<AppList_ShowPopup type="1">1</AppList_ShowPopup>
<Color_NormalOne type="1">15790320</Color_NormalOne>
<Color_NormalTwo type="1">15394274</Color_NormalTwo>
<ExplorerBar_Themes type="1">1</ExplorerBar_Themes>
<General_UseTC type="1">0</General_UseTC>
<Interface_Language type="2">Russian</Interface_Language>
<RecentItemsOnToolbar type="1">1</RecentItemsOnToolbar>
<SecondToolbar_Position type="1">1</SecondToolbar_Position>
<SecondToolbar_Show type="1">1</SecondToolbar_Show>
<Startup_CheckForUpdates type="1">1</Startup_CheckForUpdates>
<ToolBar_ButtonsCaptions type="1">1</ToolBar_ButtonsCaptions>
<ToolBar_Position type="1">0</ToolBar_Position>
<ToolBar_Show type="1">1</ToolBar_Show>
<UTAutoRunList_Column_0 type="1">131000</UTAutoRunList_Column_0>
<UTAutoRunList_Column_1 type="1">65616</UTAutoRunList_Column_1>
<UTAutoRunList_Column_2 type="1">65636</UTAutoRunList_Column_2>
<UTAutoRunList_Column_3 type="1">65666</UTAutoRunList_Column_3>
<UTMainList_Column_0 type="1">66905</UTMainList_Column_0>
<UTMainList_Column_1 type="1">65606</UTMainList_Column_1>
<UTMainList_Column_2 type="1">65656</UTMainList_Column_2>
<UTMainList_Column_3 type="1">65616</UTMainList_Column_3>
<View_Updates type="1">1</View_Updates>
<Wizard_Action type="1">1</Wizard_Action>
</PortableProgramData>- Steven
Window_nHeight and Window_nWidth were zeros and you put ones?
MrT
The program works correctly on our Windows 7 X64.
1. Does it save other preferences? Toolbars positions for example.
2. If yes, could you please run this version with /log parameter? It will output some lines when closing the program. Try closing it in normal state with changed width/height/position, and in maximized state. Thank you.
Steven, no, it doesn't save toolbar position.
MrT
This is all very strange, it saves "Interface_Language" for example.
FYI: Uninstall Tool does not save window position if you start it with command line or context menu "Install and Trace"
Steven, I've just click "finish" with checked option to launch Uninstall Tool after installation was compete. I've tried to reinstall it right now and again the same problem.
MrT
I'll prepare a special testing version with detailed log tomorrow, it may help to locate the reason of the problem. Keep in touch.
