Window size and position
MrT
Re: Window size and position
Post by MrT »
Steven, ok. Thank you.
please run this version with /log parameter? It will output some lines when closing the program. Try closing it in normal state with changed width/height/position, and in maximized state. Thank you.
MrT
Post by MrT »
Steven, I've saved this executable UT folder, deleted preferences file and made what you wrote. It showed message "window position closed" both times and was starting with correctly saved window size and position.
MrT
I've changed the way Uninstall Tool saves preferences, hope it works now. Download
MrT
Post by MrT »
Steven, should I rename it to UninstallTool.exe and overwrite original or just copy and change my shortcuts to this new file?
MrT
Yes you can just rename it to "UninstallTool.exe" and overwrite the original, I'll add this fix in the next future official build. Thank you a lot!
MrT
Post by MrT »
Steven, done. Thank you.
MrT
Post by MrT »
Steven, I've upgraded to Windows 8 and again got the same issue.
Using the latest version? Please share your 'preferences.xml' file.
MrT
Post by MrT »
Yes, I've installed Windows on 26th or 27th and downloaded the program frmo the site.
<?xml version="1.0" encoding="UTF-8" ?>
<PortableProgramData version="1">
    <AppList_HighlightRecent type="1">1</AppList_HighlightRecent>
    <AppList_HighlightX64 type="1">1</AppList_HighlightX64>
    <AppList_IconSize type="1">0</AppList_IconSize>
    <AppList_ShowPopup type="1">1</AppList_ShowPopup>
    <CheckForBetaVersions type="1">0</CheckForBetaVersions>
    <Color_NormalOne type="1">15790320</Color_NormalOne>
    <Color_NormalTwo type="1">15394274</Color_NormalTwo>
    <ExplorerBar_Themes type="1">1</ExplorerBar_Themes>
    <General_UseTC type="1">0</General_UseTC>
    <Interface_Language type="2">Russian</Interface_Language>
    <RecentItemsOnToolbar type="1">1</RecentItemsOnToolbar>
    <SecondToolbar_Position type="1">1</SecondToolbar_Position>
    <SecondToolbar_Show type="1">1</SecondToolbar_Show>
    <Startup_CheckForUpdates type="1">1</Startup_CheckForUpdates>
    <ToolBar_ButtonsCaptions type="1">1</ToolBar_ButtonsCaptions>
    <ToolBar_Position type="1">0</ToolBar_Position>
    <ToolBar_Show type="1">1</ToolBar_Show>
    <TrayIcon_HideOnClose type="1">0</TrayIcon_HideOnClose>
    <TrayIcon_HideOnMinize type="1">0</TrayIcon_HideOnMinize>
    <TrayIcon_Show type="1">0</TrayIcon_Show>
    <View_Updates type="1">1</View_Updates>
    <Window7_Theme type="1">0</Window7_Theme>
    <Window_Maximized type="1">1</Window_Maximized>
    <Window_nHeight type="1">0</Window_nHeight>
    <Window_nWidth type="1">0</Window_nWidth>
    <Window_x type="1">0</Window_x>
    <Window_y type="1">0</Window_y>
    <Wizard_Action type="1">0</Wizard_Action>
    <UTAutoRunList_Column_0 type="1">131000</UTAutoRunList_Column_0>
    <UTAutoRunList_Column_1 type="1">65616</UTAutoRunList_Column_1>
    <UTAutoRunList_Column_2 type="1">65636</UTAutoRunList_Column_2>
    <UTAutoRunList_Column_3 type="1">65666</UTAutoRunList_Column_3>
    <UTMainList_Column_0 type="1">66905</UTMainList_Column_0>
    <UTMainList_Column_1 type="1">65606</UTMainList_Column_1>
    <UTMainList_Column_2 type="1">65656</UTMainList_Column_2>
    <UTMainList_Column_3 type="1">65616</UTMainList_Column_3>
</PortableProgramData>
I think that you maximized the window, then minimized, and then closed from context menu. Am I right?
MrT
Post by MrT »
No. The last time I've maximized and closed from context menu. Before I've even tried to start with administrator priviledges.
http://www.youtube.com/watch?v=gL8AeC0Q9Sk
1. Run the program
2. Close the program in non-maximized state
3. Run the app again
3. Maximize and close
Does it save?
MrT
Post by MrT »
Steven, yes, it saved the maximzed position :) The "maximized flag" needed to be overwritten?
MrT, there's a small issue about that. When you run the app FIRST TIME, it doesn't save in maximized state under some circumstances. It will be fixed in the next build, thank you
MrT
Post by MrT »
Thank you :)
MrT
Post by MrT »
Steven, thanks.
