wolfxr
error replacement applet "Add / Remove Programs"
13 Mar 2010, 05:09
Today happened to notice that the "Uninstall Tool" does not replace the standard "installation or Remove Programs" by issuing such a mistake SCREEN. Previously, this was not replaced and all is normal. I am therefore I go under the admin account that it still needed?
wolfxr
Re: error replacement applet "Add / Remove Programs"
13 Mar 2010, 06:58
just checked 2.9.6 is replaced by a normal 5100 and the last is not replaced, wrote that there is no access rights
if you install the replacement when installing it all works, but if you then turn itself on and off this option you wrote that there is no access rights
13 Mar 2010, 11:40
wolfxr
thank you very much for the report, the issue will be fixed as soon as possible
17 Mar 2010, 20:51
wolfxr,
1. Does the file "utool.cpl" exist in program folder?
2. Do you have 32 or 64 bit version of Windows XP?
wolfxr
18 Mar 2010, 03:30
"utool.cpl" is exist and I use 32-bit version
and I am the only user of the system and therefore I am one administrator
18 Mar 2010, 12:41
wolfxr
Thank you.
Could you please test this build?
http://www.crystalidea.com/downloads/ut ... rbuild.exe
wolfxr
19 Mar 2010, 03:28
same, wrote that I have no access rights
19 Mar 2010, 07:30
wolfxr
please run the build before with
"C:\Program Files\Uninstall Tool\utool.exe" /log
and show us the log, please
wolfxr
19 Mar 2010, 08:51
Just find the following, the option is replacing the applet works if the program run from a folder or shortcut to any place, but I fixed it in the Start menu, and when you run out option is broken giving an error of access rights. :o
Here log
19 Mar 2010, 13:17
Please check 2.9.7 - it should work.
Thank you
wolfxr
19 Mar 2010, 13:20
Yes, the new version everything works, thanks!
19 Mar 2010, 13:23
Great :smile:
Thank you for feedback.
