Love This App
Morisato
Love This App
Post by Morisato »
I have a Nvidia GPU and installed Mafia 2 demo which automatically installed physx. After which I switched to an ATi card and got rid of my old Nvidia. Thing is when I went to Uninstall Program through windows, it gave an error and I could not uninstall it. I ran Uninstall Tool and it work flawlessly. Another reason to use this great app. I've yet to see any improvements that need to be made for it yet but for some reason I've usually used Windows Uninstall rather than UT's from a past experience that I had that it didn't full uninstall an app I had before. Maybe its totally different this time. Does the functions that UT use to uninstall a software/game follow the way Windows Uninstall program uses?
Re: Love This App
Dear Morisato,
Thank you for your kind words.
Uninstall Tool uses its own algorithms in finding and removing program traces, but in most cases it first runs the same default program uninstaller as it's defined for a certain app. It should be done prior to finding and removing leftover traces.
PS. Mafia was a great game in former times :good:
Morisato
Re: Love This App
Post by Morisato »
Is it possible to make an option to have previous installed apps highlighted still until a more recent installed app occurs instead of just disappeared after being shown once?
Re: Love This App
You can click on the "Installed On" column header and all new apps will be on the top of the list.
Rafel
Re: Love This App
Post by Rafel »
Recently i purchased a portable version of your great uninstaller and I'm very very happy. Runs smoothly and without any kind of problem.
Keep up the good job.
A happy Uninstall Tool user.
Re: Love This App
Rafel
Thank you for this great feedback!
Uninstall Tool improvement will never stop.
