sunburn20
Feature Request: Windows check box disable if it runs in VM
01 Oct 2015, 11:27
hi,
during boot from a Bootcamp Partition with Parallels ,
MacsFanControl opens a window that it can't be loaded in a VM
Is it possible to supress that warning box (possibly by a config setting),
because it needs a confirmation click all the time.. :smile:
Re: Feature Request: Windows check box disable if it runs in VM
01 Oct 2015, 16:07
sunburn20
Well, OK. I could add a command line switch ? (/S)
sunburn20
03 Oct 2015, 13:27
yes, that's ok. Tnx :D
