Today I launched up my mac and, as usual, went to push the fan to full force while building some apps. Usually it's fine, but it said that there was an update and I was a version behind. I clicked the link and also started the program to turn it on, but found that it was reporting min and max speeds of 0rpm.
Oh well, that should just be an issue in the update and, if not, I'll just reset the SMC as advised.
Updated and started it only to find the same update dialog. Checked version: 1.4.3. That's the best I could find on the site.
Anyone else having this issue? Still getting 0 rpm for min, max and current, but that's probably unrelated.
Update dialog still showing after update
Please re-download version 1.4.4, it must be fixed now.
thanks
thanks
Cheers mate.Steven wrote:Dear sir,
thanks
That seemed to have fixed not only the update error from that other thread, but the 0 rpm error too.
Thanks for the good software
Where is V1.4.4 located?
Because the version on your main website is v1.4.3 although right above the link, it says v.1.4.4.
Please advise so I may fix the issue with v1.4.3, which does NOT work
