hey thx for the nice app but i think something is missing
like my mbp has only 1 fan
what i kinda want is
(example)
gpu temp rises above 70= fan turns on (this works fine now)
cpu temp rises above 70 = fan turns on(works now aswel but only 1 sensor at the time)
like i said is it possible to add that if sensor 1 is to hot the fans runs faster and if sensor 2 gets to hot it turns on aswel
now you can only set 1 sensor per fan
thx for reading if you need more info just ask
