Update will not install
Locked
jmw3025
Post by jmw3025 »
I'm on Macs Fan Control v. 1.4.1.0 on an iMac running OSX v10.12.2 (current). Every time I start up my machine, Software Update tries to install an update of Macs Fan Control, but the update will not install. Any suggestions?
Re: Update will not install
Please download and install (orverwrite) the update manually:
https://www.crystalidea.com/downloads/m ... _test3.zip
jmw3025
Post by jmw3025 »
I get a 404 error when i click the link you provided.
It's now officially in 1.4.7
jmw3025
Post by jmw3025 »
When I use the drop down menu to "Check for Updates" then click to install, I get a window that says, "error extracting the update." So, I'm stuck on v. 1.4.1
Locked
