ybg
MacBook Pro 13" + Ambient temp. higher than it really is...
13 Apr 2017, 11:57
Since 2 days now, my laptop started making afwul fan noises. Like, I bought it 4 months ago and haven't had any problem since.
I don't use it this much since I study journalism and the app I run the most is Microsoft Word.
Actually, it's 20 degrees C in my room and the MFC app shows 31.5. Howcome? Can anyone help me ? Should I take it at Apple Store ?
Thank you,
a french speaking guy who hardly gets
ybg
Macs Fan Control 1.4.7
MacBookPro12,1
CPU: Intel(R) Core(TM) i5-5257U CPU @ 2.70GHz [100]
GPU: Intel Iris Graphics 6100
macOS 10.12.4
Right Side-min{1299}curr{0}max{6199}mode{0}
TA0P (Ambient) - 31.5, 31.5
TB0T (Battery Max) - 28.0977, 28.0977
TB1T (Battery Sensor 1) - 27.1992, 27.1992
TB2T (Battery Sensor 2) - 26.2969, 26.2969
TBXT () - 28.0977, 28.0977
TC0C (CPU Core 1) - 41, 41
TC0E () - 43, 43
TC0F () - 43.6367, 43.6367
TC0P (CPU Proximity) - 37.875, 37.875
TC1C (CPU Core 2) - 39, 39
TCGC (GPU PECI) - 42, 42
TCSA () - 40, 40
TCXC (CPU PECI) - 41.8594, 41.8594
TH0A () - 31.625, 31.625
TH0B () - 31.125, 31.125
TH0C () - 31.875, 31.875
TH0F () - -1, 210.426
TH0R () - -1, 202.875
TH0V () - 29.9922, 29.9922
TH0a () - 31.625, 31.625
TH0b () - 31.125, 31.125
TH0c () - 31.875, 31.875
TH0x () - 31.875, 31.875
THSP () - -1, 129
TM0P (Memory Proximity) - 34.875, 34.875
TMLB () - -1, 129
TPCD (Platform Controller Hub Die) - 40, 40
TW0P () - -1, 129
Th1H (Heatsink Proximity) - 32.875, 32.875
Ts0P (Palm Rest) - 26.625, 26.625
Ts0S () - -1, 129
Ts1P () - 26, 26
Ts1S () - -1, 129
Ts2S () - 29.8867, 29.8867
APPLE SSD SM0128G - 31.625
Re: MacBook Pro 13" + Ambient temp. higher than it really is...
24 Apr 2017, 11:36
"it's 20 degrees C in my room and the MFC app shows 31.5"
It's 100% normal. It's warmer inside the macbook
