kstheory
Excessive wakeups system diagnostic reports on OS X 10.11.6
29 Apr 2017, 19:02
For the past week, I have seen 3-4 system diagnostic reports being written by OS X El Capitan. The reports are all related to wakeups.
Here is the line in the system log:
4/29/17 1:43:34.000 PM kernel[0]: process MacsFanControl[14593] caught causing excessive wakeups. Observed wakeups rate (per sec): 211; Maximum permitted wakeups rate (per sec): 150; Observation period: 300 seconds; Task lifetime number of wakeups: 45083
Here's the top of the corresponding system diagnostic report. I can post more if required:
Date/Time: 2017-04-29 13:40:00 -0400
OS Version: Mac OS X 10.11.6 (Build 15G1421)
Architecture: x86_64
Report Version: 19
Command: MacsFanControl
Path: /Volumes/VOLUME/Applications/Macs Fan Control.app/Contents/MacOS/MacsFanControl
Version: 1.4.7.0 (???)
Parent: launchd [1]
PID: 14593
Event: wakeups (microstackshots only)
Wakeups: 211 wakeups per second for 214 seconds
Duration: 214.00s
Steps: 205
Hardware model: MacPro1,1
Active cpus: 4
Fan speed: 1302 rpm
Powerstats for: MacsFanControl [14593]
UUID: F9AE2362-C29D-32AC-84D5-DAC9A44A41B0
Start time: 2017-04-29 13:40:22 -0400
End time: 2017-04-29 13:43:34 -0400
Parent: launchd
Microstackshots: 23 samples (11%)
Primary state: 13 samples Non-Frontmost App, User mode, Thread QoS Legacy
User Activity: 0 samples Idle, 23 samples Active
Power Source: 0 samples on Battery, 23 samples on AC
8 thread_start + 13 (libsystem_pthread.dylib) [0x7fff88f1c351]
8 _pthread_start + 168 (libsystem_pthread.dylib) [0x7fff88f1e91a]
8 _pthread_body + 131 (libsystem_pthread.dylib) [0x7fff88f1e99d]
8 ??? (QtCore + 170628) [0x103110a84]
8 ??? (QtCore + 157654) [0x10310d7d6]
8 QtConcurrent::RunFunctionTask<void>::run() + 35 (MacsFanControl) [0x1023a3f23]
3 QFanControl::ControlFanSpeedThread() + 1552 (MacsFanControl) [0x1023a1350]
3 QSmcControl::setFanRPM(int, QSmcControl::RPMType, int) + 99 (MacsFanControl) [0x1023ab823]
3 QSmcControlMac::OS_WriteKey(char const*, unsigned char const*, unsigned char) + 250 (MacsFanControl) [0x10241cdba]
3 setKey_external(NSString*, NSString*) + 220 (MacsFanControl) [0x10241cc2c]
3 -[NSConcreteTask launchWithDictionary:] + 3408 (Foundation) [0x7fff9365cbef]
3 +[NSPort port] + 36 (Foundation) [0x7fff9361a1f6]
3 -[NSMachPort init] + 141 (Foundation) [0x7fff9361a298]
3 -[NSMachPort initWithMachPort:options:] + 278 (Foundation) [0x7fff935e8f1f]
3 object_dispose + 22 (libobjc.A.dylib) [0x7fff8ded3d0d]
2 objc_destructInstance + 129 (libobjc.A.dylib) [0x7fff8ded3db8]
2 _object_remove_assocations + 157 (libobjc.A.dylib) [0x7fff8ded9cf7]
Here's my technical info from MFC. Note that I've also attached a screenshot of MFC running now (80 minutes later):
Macs Fan Control 1.4.7
MacPro1,1
CPU: Intel(R) Xeon(R) CPU 5150 @ 2.66GHz [100]
GPU: ATI Radeon HD 5770
macOS 10.11.6
CPU_MEM-min{500}curr{1282}max{2900}mode{2,TC0P,28,50}
IO-min{500}curr{2095}max{2900}mode{2,TS0C,28,38}
EXHAUST-min{500}curr{1282}max{2900}mode{2,TC0P,28,50}
PS-min{720}curr{2201}max{2800}mode{2,TS0C,27,38}
TA0P (Ambient) - 30.5, 30.5
TC0C (CPU A Core 0) - 56, 44
TC0P (CPU Proximity) - 36.875, 36.875
TC1C () - -1, 0
TC2C (CPU B Core 0) - 58, 42
TC3C () - -1, 0
TCAH () - 34.3125, 34.3125
TCBH () - 35, 35
TH0P (Drive Bay 0) - 31.5, 31.5
TH1P (Drive Bay 1) - 31.5, 31.5
TH2P (Drive Bay 2) - 31, 31
TH3P (Drive Bay 3) - 31.5, 31.5
THTG () - 45, 45
TM0P (DIMM Module 1 Proximity) - 34, 34
TM0S (FBDIMM Riser A Slot 1) - 52.5, 52.5
TM1P (FBDIMM Riser A Outgoing Air) - 37, 37
TM1S (FBDIMM Riser A Slot 2) - 58, 58
TM2P (FBDIMM Riser A Regulator Area) - 35, 35
TM2S () - -1, 129
TM3S () - -1, 129
TM8P (FBDIMM Riser B Incoming Air) - 35, 35
TM8S () - 55, 55
TM9P (FBDIMM Riser B Regulator Area) - 38, 38
TM9S () - 62, 62
TMAP () - 38, 38
TMAS () - -1, 129
TMBS () - -1, 129
TN0H (MCP Heatsink) - 48.5, 48.5
TS0C (Expansion Slots) - 34.5, 34.5
Tp0C (PSMI Supply AC/DC Supply 1) - 39, 39
Tp1C (PSMI Supply AC/DC Supply 2) - 33.5625, 33.5625
Tv0S () - 35.2188, 35.2188
Tv1S () - 35.3711, 35.3711
WDC WD10EZEX-00WN4A0 - 35
WDC WD30EZRZ-00WN9B0 - 33
Samsung SSD 850 EVO 120GB - 33
Re: Excessive wakeups system diagnostic reports on OS X 10.11.6
07 May 2017, 19:17
This is a known issue and it will be improved.
kstheory
11 Jan 2018, 17:28
I'm wondering if the "Minor small improvments" in 1.4.9 included a fix to this.
I am still getting daily excessive wakeups diagnostic reports. (Same set-up as my initial post: running El Capitan 10.11.6 on MacPro 1,1.)
Thank you.
11 Jan 2018, 17:30
Users browsing this forum: Bing [Bot] and 2 guests
