Memory temp on MacPro 3,1
Jief
Post by Jief »
memory temp are not display correctly on a macpro 3,1. I have just slot 1 and 2, where i have eight FBDIMM modules.
The eight SMC sensor are TM0S,TM1S,TM2S and TM3S for Riser A and TM8S,TM9S,TMAS and TMBS for Riser B. There is also 6 proximity sensor TM0P, TM1P, TM2P for riser A and TM8P, TM9P, TMAP.
Would be nice to have that fixed.
Also, would be good to be able to configure something like : if one of the memory temperature is going to high, let's increase fan speed. So, for a sensor base value, maybe a way to enter more than one sensor ?
Regards.
Re: Memory temp on MacPro 3,1
Please provide some more information for us:
https://forums.crystalidea.com/viewtopi ... =11&t=1006
Jief
Post by Jief »
Yep, technical confirm what I've said.
Macs Fan Control 1.4.8.1
MacPro3,1
CPU: Intel(R) Xeon(R) CPU E5462 @ 2.80GHz [100]
GPU: AMD Radeon HD 7xxx
macOS 10.10.5
CPU_MEM-min{500}curr{946}max{2900}mode{0}
IO-min{800}curr{797}max{2900}mode{0}
EXHAUST-min{600}curr{1042}max{2900}mode{0}
PS-min{600}curr{598}max{2800}mode{0}
TA0P (Ambient) - 24.375, 24.375
TC0C (CPU A Core 0) - 36, 64
TC0D (CPU Diode) - 30.5938, 30.5938
TC0P (CPU Proximity) - 34.5625, 34.5625
TC1C (CPU A Core 1) - 34, 66
TC1D () - 31.0625, 31.0625
TC2C (CPU B Core 0) - 34, 66
TC2D () - 31.875, 31.875
TC3C (CPU B Core 1) - 43, 57
TC3D () - 31.9062, 31.9062
TCAG () - 80, 80
TCAH () - 28.4375, 28.4375
TCBG () - 80, 80
TCBH () - 29.625, 29.625
TH0P (Drive Bay 0) - 26.125, 26.125
TH1P (Drive Bay 1) - 28.125, 28.125
TH2P (Drive Bay 2) - 28, 28
TH3P (Drive Bay 3) - 28.375, 28.375
TM0P (DIMM Module 1 Proximity) - 38, 38
TM0S (FBDIMM Riser A Slot 1) - 64.5, 64.5
TM1P (FBDIMM Riser A Outgoing Air) - 34, 34
TM1S (FBDIMM Riser A Slot 2) - 57.5, 57.5
TM2P (FBDIMM Riser A Regulator Area) - 38, 38
TM2S () - 46.5, 46.5
TM3S () - 45.5, 45.5
TM8P (FBDIMM Riser B Incoming Air) - 38, 38
TM8S () - 73.5, 73.5
TM9P (FBDIMM Riser B Regulator Area) - 42, 42
TM9S () - 77, 77
TMAP () - 43, 43
TMAS () - 67.5, 67.5
TMBS () - 53.5, 53.5
TN0C () - 47.9688, 47.9688
TN0D (MCP Diode) - 63.5, 63.5
TN0H (MCP Heatsink) - 35.5, 35.5
TS0C (Expansion Slots) - 30.5, 30.5
Tp0C (PSMI Supply AC/DC Supply 1) - 51, 51
Tp1C (PSMI Supply AC/DC Supply 2) - 52.1406, 52.1406
Tv0S () - 25.043, 25.043
Tv1S () - 25.168, 25.168
SAMSUNG MZ7PD256HAFV-000H7 - 28
SanDisk SDSSDHP256G - 31
WDC WD4003FZEX-00Z4SA0 - 34
MTFDDAK512MBF-1AN1ZABHA - 32
Jief
Post by Jief »
Sorry, but the site said "Failed to move uploaded file". So I can't put a screenshot. But nothing special on it anyway.
