Itzamna
Setting a rpm value
27 Dec 2017, 04:16
Hello there. I'm currently using smcFanControl but I would like to switch to MFC, but I have a question.
If I set the rpm value to a custom number, if the system sees it needs more fan speed, does it increase? Does the custom value work like a minimum value to the fan speed? Or it's a fixed value no matter what?
Plus, if I want to remove the application, it's just a matter of deleting it and restarting?
Re: Setting a rpm value
27 Dec 2017, 22:59
"Or it's a fixed value no matter what?"
Yes, fixed.
"[font=-apple-system, Helvetica Neue, Helvetica, sans-serif]if I want to remove the application, it's just a matter of deleting it and restarting?"[/font]
Simply return the fan(s) to Auto and delete. No restart required.
Users browsing this forum: Bing [Bot] and 2 guests
