skyshaper
multiple MFC installed and do not show up in Applications
30 Dec 2017, 11:53
Hi thank for Macs Fan Control!
After installing the latest update, v149, my old version v148 is still running alongside and keeps reminding me about update. It seems I have two versions installed when I search in Spotlight but neither shows up when I look into the Application folder. How can I uninstall the old version, or better everything, and then install from scratch?
I run OSX 10.9.5 on an MacBook Pro 17" 2011.
Cheers!
Re: multiple MFC installed and do not show up in Applications
02 Jan 2018, 14:47
Simply remove the old version from Applications.
skyshaper
13 Jan 2018, 07:59
Hi Steven
thanks for your reply! However no versions of Macsfancontrol were visible in the Application folder. I first thought they were installed somewhere else or hidden.
I now found a way by searching for Macsfancontrol in Spotlight, then opening Containing Folder with Command+R in order to be able to delete them.
Works fine now with v149 thanks!
Best,
skyshaper
13 Jan 2018, 08:12
hi again
I just learned that there are two Applications folders in my Mac and that Macsfancontrol are one of the few to be installed in ~/Applications/  (the Home directory for my user account) and not the "top" /Applications/ directory where all the other programs are found. So that's why it didnt show up in the "normal" Appiication folder! I also found some other old programs there like "STAR WARS Knights of the Old Republic" that I forgot I had installed :D
Thanks again for a great program. A life saver to keep the temperature down for my 2011 MacBok Pro with the know GPU glitch and using Bootcamp Windows 7 as extra.
