Assign control monitoring to an alternate or multiple sensor
carbonatd
Post by carbonatd »
Great app! I'm wondering if there is any way to assign fan control based on the temperatures from separate sensor readings? The temperature reading this app seems to focus on is the main CPU diode.. Is there any way to configure this app to monitor GPU temperature as well? I noticed that while my gpu temperatures spiked, (73c,), my cpu diode remained at a low(ish) 69c, 156f, and this app did not increase fan speed.
Thanks!
Re: Assign control monitoring to an alternate or multiple sensor
I'm planning to support more than 1 sensor. That can be useful for MacMini and some MacBook Pro models.
The main focus is currently on stability of the current functionality (most sensor-based control)
