Some issues in Windows 8 pro
enriquersc
Post by enriquersc »
Good morning, thanks for the application, just in bootcamp windows 8 does not start automatically when you start Windows 8, I have a Macbook Pro 8.1, otherwise, in the mac performance reaches 100 º C so I must keep energy options in economizer or balanced, thanks and happy day
P. D. The version I'm using Macs Fan Control 1.0.1
Re: Some issues in Windows 8 pro
This is sad. Unfortunately I do not have any mac running Windows 8
Do you have UAC off?
debush
Post by debush »
In my case I have had UAC turned off ( always have it off).
Dale
debush
Post by debush »
Somehow my earlierpost on this did not register.
Auto starting in windows 8 has been a problem. I mentioned it in this forum about a month ago.
An interesting fact is that if you Activate the "Administrator" account and login as "Administrator" it DOES automatically start. I observed this when I installed 1.0 Beta 5 on Windows 8.
Dale
enriquersc
thanks for your prompt response, the fact is that if I have UAC disabled, I tried uninstalling and reinstalling the application, but it seems that the moment I can not get it working right. In any case thanks for the effort, Greetings from Guatemala
PD. Sorry for the delay in my response.
Windows 8 autostart issue is fixed in 1.0.3
