S.M.A.R.T. reporting issue with Macs Fan Control
FajitaMidland
Post by FajitaMidland »
In testing your Macs Fan Control today, I noticed that the program causes a problem with S.M.A.R.T. being reported correctly on the iMac. This occurs with either the Apple Disk Utility or a program called SMART Reporter.
For those wanting to check this on their computers launch Apple Disk Utility and then click on your hard drive and then click the blue info icon. Look for S.M.A.R.T. Status -- do this with the Mac Fan Control running and also without it running.
Mac Fan Control Running with the Apple disk utility I receive the following statement:
S.M.A.R.T. Status : Not Supported
Mac Fan Control Running SMART Reporter I get this error:
smartctl 6.1 2013-03-16 r3800 [x86_64-apple-darwin12.3.0] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, http://www.smartmontools.org
Read Device Identity failed: Unknown error
=== START OF INFORMATION SECTION ===
Device Model: [No Information Found]
Serial Number: [No Information Found]
SMART support is: Ambiguous - ATA IDENTIFY DEVICE words 82-83 don't show if SMART supported.
SMART support is: Ambiguous - ATA IDENTIFY DEVICE words 85-87 don't show if SMART is enabled.
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
Quitting your Mac Fan Control program the Apple Disk Utility states: S.M.A.R.T. Status : Verified
Now SMART Reporter works with the following information:
Model Family: Samsung based SSDs
Device Model: Samsung SSD 840 PRO Series
Serial Number: XXXXXXXXXXXXXXXXXXX (MASKED OUT BY ME)
LU WWN Device Id: 5 002538 550360588
Firmware Version: DXM05B0Q
User Capacity: 512,110,190,592 bytes [512 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4c
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sun Jun 30 23:08:29 2013 CDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Etc...
Re: S.M.A.R.T. reporting issue with Macs Fan Control
Should be fixed in 1.0.4, please check
FajitaMidland
Yes version 1.0.4 is fixed! Thanks for quick response.
