AnyoISO 3.6.2 problem and activation problem
Ask, answer questions, and express your opinion about AnyToISO. Discussion of bugs and problems found in AnyToISO, feature requests
tsanchai
Post by tsanchai »
I have just downloaded and update AnytoSIO to version 3.6.1 and here are problems that needed to be fixed immediately.
1. After upgraded to 3.6.2, when I open the app it run fine. When I click on About, it show version 3.6.2 correctly. When I click Check for Update, the app show that I have the latest version. But when I click on the App in Applications folder, the version shown is 3.6.1
Fix please, when I click on the app in Applications folder, it should show 3.6.2 not 3.6.1! This cause Macupdate to have false alarm that I have 3.6.1 on my system and the latest version is 3.6.2
2. When I start AnytoISO, it show that I have a Pro version. But when I click on About, it show that the app run in Lite version. I entered my registration key, AnytoISO accept it and ask me to restart the app. But when I click on About, again, it run as Lite but the main app window showing I am running Pro version
Fix please this is very confusing
Re: AnyoISO 3.6.2 problem and activation problem
tsanchai
Thank you! Both issues are fixed, please re-download the app.
tsanchai
Post by tsanchai »
Hey! you have mistake again. When I click on AnytoISO in Applications folder, it reads version 2.6.2 not 3.6.2!
If I click check for update, it show that I have version 3.6.2 and about window in the app also show 3.6.2 and registered as Pro version correctly
May be you made a typo and needed to be fixed one more time to 3.6.2!
To err is human! Cheer and fix it please
Sorry, fixed.
