Hi there,
I have a Mac, and your AnyToIso software.  I have converted several NRG files, and when I tried to open or burn any of them, they all say that they cannot be opened, reason: not recognised.
Please help me!  I am currently trying to see if they will write OK on a PC, but it will take some time to transfer them across.  Also, the only writing software I have on my PC is Nero, and I'm not sure if it works it will be because of that
Any help is appreciated.
Pete
Edit:
Further to this, I have now tried converting with the PC version of the software, and can burn the ISO files it makes, but only have Nero to write with.  I have copied one of the ISO files from the Mac, and I can write that OK on the PC.  Interesting to note that there is a discrepancy in the file size between the Windows and the Mac formats.  About to try writing the PC converted file on a Mac, will update you shortly.
Edit 2:
The conversions on the PC cannot be written on a Mac.  Same error: not recognised.  I will see if I can test using another piece of software to burn the ISO files on the PC, other than Nero.
	Mac: Cant use ISO after converting from NRG
Re: Mac: Cant use ISO after converting from NRG
PeteC
Can you please share one that NRG file with us in order to fix the issue? Any way is acceptable - http/ftp/torrent, any free file hosting.
Thanks for your reply, uploaded here:
http://www.megaupload.com/?d=YZFUIDRZ
Look forwards to your feedback.
Dear PeteC.
Thank your for feedback. Actually I meant to upload the original NRG file.
Actually this ISO file is 100% valid, and it actually contains an image of a 1.44 Floppy disk image (FAT12, NOT CD)
I have extracted it with a 3rd party software and created a CD ISO with its contents (with AnyToISO "Folder to ISO" function):
http://www.sendspace.com/file/xqkqxu
My apologies, I mis-read, I will upload the NRG file next time I am in the office.  Is there any way other than extracting the ISO with software that isn't yours, and then creating the ISO again as to making it mount' burn on a Mac?  My company has purchased your software to consolidate our library of disks to ISOs for simplification and writing on a Mac, none of the NRG files we have converted mount/burn on a Mac.
Dear PeteC
AnyToISO is specialized for working with ISO images of CD/DVD/Blue-ray images, not floppy 1.44MB images and FAT12 file system, which are deprecated.
AnyToISO complete technical guide
Strangely enough today most of the ISO's are working! The few that don't work are two DVDs, which are 3+gb to upload, which I can't upload due to time and bandwidth constraints. With these particular ones (as it's just 3 in a total of 20 or so) I can always re-image them on the Mac, it was the general thing that was an issue for me. Thank you for your help, can you please let me know what software you used to unpack the PcCheck ISO?
Pete
Pete
Dear Pete,
If you have any problems with some images, please try uploading them or give us torrent/ftp/http link. This will help fixing any issue (if it exists) promptly.
I'm afraid this option will not be implemented in near future. 1.44 MB images and FAT12 file system are history today
