joger972
File name are changed in ISO
21 Apr 2015, 14:07
Trying to make a folder to ISO I get an ISO with file names changed with a number replacing the last letter. I noticed that it is done when same name in the same folder even with different extension
ex: sample.ini and sample.exe are changed to sampl1.ini and sampl2.exe :x
so when I launch sampl2.exe the launcher says it can't find the sample.ini... :%)
Re: File name are changed in ISO
22 Apr 2015, 05:52
Could you please share an example of such a folder? Compress it with zip
joger972
22 Apr 2015, 17:07
Sorry... :oops:
I was testing some Virtual Machines (Parallels Desktop) with some old Windows versions I kept in box... then I noticed the problem comes only with DOS/Win3.11 and Windows 95 No problem with the software itself. :no:
So..sorry... :shock: :oops:
