eqtstar
Any ISO converted file won't mount in Windows
09 Nov 2016, 11:38
When I convert any files such as DMG or what have you then try to mount the iso as a virtual drive in windows it does not mount. Have tried to burn iso's to dvd and programs say that it is corrupt file. Tried in Windows 7, 8.1 and 10 and same result. Is this common? I tried to use to mount load disks for VM software as well. Is this a known issue, as I just purchased and started using this product? Thx in advance.
09 Nov 2016, 14:45
AnyToISO keeps the DMG file system when converting to ISO (normally it's HFS+). Thus the resulting ISO contains HFS+ FS.
Windows doesn't support this file system by default.
PS. https://www.google.com/webhp?sourceid=c ... t%20hfs%2B
