Cor'e =)
AnyToISO v3.4 crashes when i use it... WinXP Pro x32 SP3
12 Aug 2012, 19:31
Just installed your AnyToISO v3.4 and it crashes when i use it to try to convert a BIN to ISO, i'm on WinXP Pro x32 SP3, i've uninstalled it and reinstalled, i've checked the download for viruses, i've tried it via the context menu, can't figure this out.
The instruction at "0x7c910cce" referenced memory at "0x3f004003". The memory could not be "read".
Re: AnyToISO v3.4 crashes when i use it... WinXP Pro x32 SP3
12 Aug 2012, 19:32
Cor'e =)
What BIN image did you tried? Can you share it with us?
Cor'e =)
12 Aug 2012, 19:36
It is rather large, do you need a piece of it? Since you are indicating it matters, i'll try another BIN asap too.
Here's the .CUE contents:
FILE "GV.bin" BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
12 Aug 2012, 19:41
Cor'e =)
12 Aug 2012, 20:53
Well, that took some time, plz don't ask me to that again (i'm metered by bytes).
Now that you have it, tell me what's going on, i cannot think that the BIN file chosen would cause this type error, it seems to be the programming of the AnyToISO executable itself imho, but let me know, tia!
12 Aug 2012, 22:29
Cor'e =),
Thank you. I'll keep you informed on the issue tomorrow.
13 Aug 2012, 15:46
Cor'e =),
Fixed! thank you, please test
Cor'e =)
13 Aug 2012, 18:32
That's Quick! =)
