Is this error mean that this file is DOA or is this an issue with the converter? I would be happy to send the file (450mb).
TIA~!
Error: cannot find ISO_9660 signature, reached 5 MB limit
momentarylapse
Re: Error: cannot find ISO_9660 signature, reached 5 MB limit
Dear momentarylapse,
What is the file format? You can upload the file on any free file hosting (http://www.google.com./search?sourceid= ... le+hosting)
same issue here with a Bin file; AnyToIso product info says it can convert BIN to ISO files but apparently not. My Mac version gives error message it cant find signature and 5mb limit reached. MagicISO-Windows had no problem and converted it to a working ISO file. Just purchased AnyToIso for i thought it could do all the jobs and dont have to juggle with two OS; dissapointing..
Dear robbert,
We contacted you via e-mail.
Thanks to robbert
the issue is reproduced, a quick fix will be released soon.
BIN file issue solved. ISO-convert/BIN-extraction now works with 3.2.2. Thanks for the fast fix, Crystalidea!
No problem, robbert
Thank you!
Thank you!
