badai
Running Pale Moon
21 Nov 2011, 07:35
possible to set "firefox" executable to run after optimize, like setting the path of profile using /profile:my_pale_moon_profile?
Re: Running Pale Moon
21 Nov 2011, 08:56
badai
We'll consider adding Pale Moon support to future versions, thanks.
badai
21 Nov 2011, 09:58
in the mean time, this batch file will do:
speedyfox.exe /profile:"pale moon profile"
"C:\Program Files\Pale Moon\palemoon.exe"
27 Mar 2012, 19:33
Complete support in done in 2.0.1
hassan123
21 Oct 2014, 07:22
I have profiles for Firefox and Palemoon in both Appdata/Local and Appdata/Roaming. Speedyfox does the roaming profiles well, but when I try to get it to do the local profiles I get an error message that a profile cannot be detected and to contact the forum. Both have urlclassifier3.sqlite files that are 35 MB in size. Thanks
Are you worried about 70-640 exam questions - braindumps.com prep and ICMA
