mhusen
"Unable to Detect" - Portable Firefox Profile
24 Mar 2012, 19:08
Using new Speedyfox-2, I am trying to optimize a Firefox profile located at:
"c:\Firefox\FF10\Data\Profile"
and all I keep getting is a message:
"Speedyfox was unable to detect any browser/supported program in specified path"
Please help.
Unfortunately I have deleted Speedyfox-1.6 from my system, which worked perfectly well - where can I download the old version 1.6?
Re: "Unable to Detect" - Portable Firefox Profile
25 Mar 2012, 12:55
mhusen
Please try this build
dziubek
25 Mar 2012, 15:33
I had the same problem with portable version. This version fixes it.Portable version detected automatically at startup
Thanks Steven :)
25 Mar 2012, 17:22
dziubek
:good:
antbil007
25 Mar 2012, 18:11
Link don't work.
Page not found (404)
The requested page/file is not found, it's probably renamed or removed.
Are you able to give us a new one?
25 Mar 2012, 19:02
antbil007
It's transformed into build 61, available at the official link:
http://www.crystalidea.com/downloads/speedyfox.exe
dziubek
26 Mar 2012, 09:54
This version doesn't detect the portable thunderbird profile on startup.
Manual selection of the destination directory does not work.(C:\Documents and Settings\Administrator\Pulpit\ThunderbirdPortable)
Only select a subdirectory of the profile enables the detection of:
26 Mar 2012, 11:33
dziubek
The program cannot detect portable versions of the program, user should specify them manually.
C:\Documents and Settings\Administrator\Pulpit\ThunderbirdPortable\Profile
mhusen
26 Mar 2012, 22:16
Steven wrote:
mhusen
Works well. :good:
Optimized 18 Firefox profile files from 12.8MB to 3.56MB - that's very impressive. :Bravo: :Bravo:
