vBm
Portability.
08 Apr 2012, 17:57
At the moment uppon run speedyfox created preferences.xml in APPDATA.
On most apps if we move preferences.xml to .exe folder, application will read stuff from it and will not create new preferences.xml in APPDATA again like speedyfox does.
In my opinion this behavior should be fixed, so preferences.xml are not created again even thou we already have 'em in .exe dir.
Thanks in advance.
Re: Portability.
08 Apr 2012, 18:44
vBm
This behavior will not be changed, because the .xml contains absolute paths to profiles (including custom).
vf2nsr
Re: Portability.
25 Apr 2012, 22:35
Who would I need to speak to to recieve permission to repackage this program into a PortableApps.com format? I am a developer for applications on their site and would love to get the permission to offer this great app. Especially given that the portable versions of Firefox as well as Thunderbird our flagship programs of the site.
Re: Portability.
26 Apr 2012, 08:23
vf2nsr
You may freely do that
vf2nsr
Re: Portability.
02 May 2012, 20:13
Thanks I have done so http://portableapps.com/node/32020
Quick question does SpeedyFox support relative path names ot must they be absolute ?
Re: Portability.
02 May 2012, 20:39
absolute
