Speedyfox can't find portable firefox profile
Top popular freeware SpeedyFox
Dvdbane
Post by Dvdbane »
speedyfox can't find portable firefox profile through command line
it only detect when the profile location is add manually
Product version : 2.0.2.64
File version : 2.0.2.63
Re: Speedyfox can't find portable firefox profile
Speedyfox cannot detect portable profiles because they are portable, one should add them manually
Dvdbane
Post by Dvdbane »
why previous version can detect portable profile??
to be exact,version 1.6
so, there no point of having command line if the profile need to add manually
thnx for reply
Dvdbane
Please do a right click on the profiles tree, 'Add custom profile'
Dvdbane
Post by Dvdbane »
i know how to add profile manually
i just want to optimize the profile using bat file without add it first to speedyfox
Try replacing the environmental variable and do not use relative paths
Shurikenix
Post by Shurikenix »
yes, if path "qqq" is not added in preferences.xml (not added manually in the speedyfox), the command line
speedyfox.exe /Firefox:"qqq"
does not work!
