Auto optimize for SpeedyFox ???
Top popular freeware SpeedyFox
AMG
Post by AMG »
Hello
Can you make a startup function for SpeedyFox ??? When the PC new started then optimize automatic FF !!! ;)
Sorry my English is not perfect Germany !!! :bad:
Re: Auto optimize for SpeedyFox ???
AMG
SpeedyFox has command line (see menu Help), you can add a new startup item with that command line for example with Uninstall Tool
AMG
Post by AMG »
Thanks i have found (/default_profile) !!! :good: :good: :good:
You're welcome.
cssoz
Post by cssoz »
what do you do with /default_profile ?? i have no idea i can't figure it out =\
Optimize default Firefox profile. The one that appears in the profile list when you open SpeedyFox window.
ander
Post by ander »
cssoz wrote:what do you do with /default_profile ?? i have no idea i can't figure it out =\
1. Right-click your SpeedyFox shortcut, then in the pop-up menu that appears, click Properties.
2. Add this to the text in the "Target:" box (preceded by a space, to separate it from the existing text):
/default_profile
3. Click OK.
Now, when you run your shortcut, SpeedyFox skips opening its window and automatically defrags your default FF profile.
Steven: Thanks for adding the option to run FF after the defrag. Nice!
Cheers, Ander
Great :smile: Thanks
