urlclassifier3.sqlite
I have profiles for Firefox and Palemoon in both Appdata/Local and Appdata/Roaming. Speedyfox does the roaming profiles well, but when I try to get it to do the local profiles I get an error message that a profile cannot be detected and to contact the forum. Both have urlclassifier3.sqlite files that are 35 MB in size. Thanks
Re: urlclassifier3.sqlite
ldb
Please post here the list of files inside that profiles and SpeedyFox version
MozillaUser233
I can 2nd this problem as well.Steven wrote:ldb
Local:Moonchild Productions:Pale Moon:Profiles
Folder:xxxxxxx.default
Folder:startupCache: In startupCache Folder is startupCache.8.little
urlclassifier.pset
Folder:xxxaaaa.default
Folder:Cache: Bunch of folders naming from 0 to 9 A to F. Bunch of cache files.
Folder:startupCache
urlclassifier.pset
Speedyfox 2.0.2
Pale Moon/Profiles/xxxxxxxx.default/
OfflineVache/index.sqlire
startupCache/startupCache.8.little
urlclassifier.pset
Mozilla/Firefox/Profiles/xxxxxxxx.default/
Cache/(a bunch of folders 1-9, A-F, 001-003 and map)
jumpListCache/(some icons)
startupCache/startupCache.4.little
urlclassifier.pset
Items in Bold are folders
Speedyfox version 2.0.2.64
urlclassifier.pset
urlclassifier.pset
Ok, guys, thank you. Will look into the issue in a couple of days.
