Is MDF version 2.X supported ?
regards , Horst
MDF ver 2.0
Re: MDF ver 2.0
Dear tummeliten,
Can you please give an example of such file or a way to create it?
Re: MDF ver 2.0
Hi ,
i created a backup (cant remember what program it was and reformatted PC since then ...) .
Alcohol 120% told me it is an MDF ver2.0 file and Alcohol only supports ver 1.X .
So i upgraded to the latest version of Alcohol and now it tells me unsupported image .....
cant open it with isobuster or Nero either ....file size is too big to send and since it is not supported
with the AnyToISO trial version i cant check if it would work.
regards
regards
Re: MDF ver 2.0
tummeliten,
We have sent you a temporary Pro version key in order to check.
Re: MDF ver 2.0
hi ,
yeah , this worked well ...ty
converted to ISO and burnt the DVD.
going to buy that full version .
regards
regards
Re: MDF ver 2.0
tummeliten
Great!
Great!
