Installation monitor doesn't work
Leopold
Post by Leopold »
Installation monitor doesn't work with some programs (Ms office, photoshop, Java). I have Windows 7 64x Sp 1.
The Windows installer gives out here such window...
Re: Installation monitor doesn't work
Leopold
1. Can you please try this version?
http://www.crystalidea.com/downloads/fi ... _setup.exe
2. Did you use .msi or .exe setup files?
Leopold
Post by Leopold »
I use the last version of program. I use *.exe setup files.
Try using the test build at this link (it contains fix for this issue):
Leopold
Post by Leopold »
Everything works, except VMware Workstation 10.0.2 Build 1744117 :(
