No matter what I do, it won't autoron. With windows 7 everything was fine. I even tried ataching the app to the registry startup. The autorun setting is enabled.
However, when I checked the startup folder, theres no icon there.
Any ideas?
Macs Fan Control 1.1.11, MacBookPro9,1, Windows 8.1
Left side-min{2000}curr{2821}max{6200}mode{2,TC0P,35,65}
Right side-min{2000}curr{2809}max{6200}mode{2,TC0P,35,65}
TA0P (Ambient) - 39.25
TB0T (Bottom Enclosure) - 33.1992
TB1T (Battery Point 1) - 33.1992
TB2T (Battery Point 2) - 32.0977
TC0E () - 56.4219
TC0F () - 58.4961
TC0P (CPU Proximity) - 44.5
TC1C (CPU Core 1) - 54
TC2C () - 55
TC3C () - 55
TC4C () - 53
TCGC () - 53
TCSA () - 53
TCXC () - 56.0781
TG0D (GPU Diode) - 47.875
TG0P () - 43.125
TG1D () - 52
TG1F () - 49.9414
TG1d () - 46
TGTC () - 0.125
TGTD () - 0.0898438
TM0P () - 36.625
TM0S (DIMM Module 1) - 40.5469
TP0P () - 40.25
TPCD () - 61
Th1H () - 41.75
Th2H () - 39.5
Ts0P (Left Palm Rest) - 30.9375
Ts0S () - 35.4492
Ts1S () - 35.1133
Tsqf () - 53.1562
Win 8.1.1 - No Autorun at all
Re: Win 8.1.1 - No Autorun at all
dream3
on Windows 8.1 MFC uses Task sheduler to create autorun entry. Can you check it?
Yeah it's there.
Trigger: At log on
Details: At log on of any user
Status: Enabled.
Even though, no autorun. However, I did spotted a weird setting under the Condition tab.
It says "start the task only if pc is on AC power". And I cant change that, it's grayed out. Why wouldnt we want macfan to run on battery?
I dont think that condition exists over the OS X side. Considering the discrete GPU cant be turned off in bootcamp, meaning the mac will always be hotter on windows, I think there are no downsides in running macfans on battery at all.
Trigger: At log on
Status: Enabled.
dream3
Thanks for sharing this info!
Can you please try this .exe?
http://www.crystalidea.com/temp/MacsFanControl.exe.zip
Please UNCHECK and CHECK "Autostart minimized with system" option.
Hey Steven!
Here's what I got when I tried to run the .exe:
Program cant start because Qt5core.dll is missing from computer. Try reinstalling...
dream3
Place this .exe to the program folder of MFC:
C:\Program Files (x86)\Macs Fan Control
Haha dumb mistake.
Anyway, you've nailed it Steven! All good now.
dream3
Great! Thank you.
The fix will be available in the next update
Great! Thank you.
