Macbook Pro 9 2 fan never speeds up
James Butler
Post by James Butler »
Hi I have an MacBook pro with a 2.5GHz intel Core i5. one thing ive notised is that the fan never seems to speed up when its controlled by the system, even if I stress the CPU the temperature will slowly rinse to 95 the fan will still run at just 2000RPM.
would anyone say this was normal?
Screen Shot 2014-06-27 at 10.33.59.png (72.87 KiB) Viewed 30945 times
Re: Macbook Pro 9 2 fan never speeds up
This is obviosly not correct.
Try cleaning the fan or use some constant or sensor based value for the fan when you need more cooling for your CPU
tanvip99999
Post by tanvip99999 »
Steven wrote:This is obviosly not correct.
i have the same issue, and lots of people have that.
The fan is only speeding up when the temperature rise over 90 degree C. At Auto mode
Macs Fan Control 1.1.11, MacBookPro11,1, Mac OS X 10.9
Right Side-min{1299}curr{1296}max{6199}mode{0}
TA0P (Ambient) - 39
TB0T (Bottom Enclosure) - 35.2969
TB1T (Battery Point 1) - 35.2969
TB2T (Battery Point 2) - 33.7969
TBXT () - 35.2969
TC0C (CPU Core 0) - 53
TC0E () - 51.8438
TC0F () - 53.6797
TC0P (CPU Proximity) - 47.625
TC1C (CPU Core 1) - 52
TCGC () - 52
TCSA () - 52
TCXC () - 52.0156
TH0A () - 40.125
TH0B () - 39.875
TH0C () - -1
TH0F () - -1
TH0R () - -1
TH0V () - 38.7344
TH0a () - 40.125
TH0b () - 39.875
TH0c () - -1
THSP () - -1
TM0P () - 43.375
TMLB () - -1
TPCD () - 48
TW0P (Airport Card) - -1
Th1H () - 40.75
Ts0P (Left Palm Rest) - 33.9375
Ts0S () - 38.0547
Ts1S () - 36.6602
Please help me. is this normal?
tanvip99999
I just bought my new macbook 15 days ago, so it's brand new.
tanvip99999
I'm sorry can't say for sure because I don't have that laptop (MacBookPro11,1)
But if it's brand new, then it looks like correct behavior.
tanvip99999
The Fan is only Speeding when temperature rise up 90 Degree C. Is is normal? Is this Apple Defaut setting and my Macbook have any problems?
Right Side-min{1299}curr{1765}max{6199}mode{0}
TA0P (Ambient) - 39.5
TB0T (Bottom Enclosure) - 34.5977
TB1T (Battery Point 1) - 34.5977
TB2T (Battery Point 2) - 33.1992
TBXT () - 34.5977
TC0C (CPU Core 0) - 95
TC0E () - 91.9336
TC0F () - 93.7344
TC0P (CPU Proximity) - 72.75
TC1C (CPU Core 1) - 89
TCGC () - 83
TCSA () - 84
TCXC () - 93.1719
TH0A () - 42.125
TH0B () - 41.125
TH0C () - -1
TH0F () - -1
TH0R () - -1
TH0V () - 39.9102
TH0a () - 42.125
TH0b () - 41.125
TH0c () - -1
THSP () - -1
TM0P () - 53.25
TMLB () - -1
TPCD () - 72
Th1H () - 51.375
Ts0P (Left Palm Rest) - 33.5625
Ts0S () - 41.3477
Ts1S () - 38.3633
tanvip99999
Thank you but I really worry about it.
90 Deegree is so hot and the Fan start speed up, but not really fast, only ~ 2000 rpm :!
I dont want set anything instead of Automatic Mode?
Any advise for me?
tanvip99999
What is fan speed when CPU is 90-95 degrees C ?
theomoto
Post by theomoto »
I own a late 2012 i5 2.5ghz mac mini. I think it's about the same cpu with yours. My advice is not to worry about it. Coming from a pc, I'd say that these temps seem a bit high but now that I use Mac hardware I'd say it's normal. I stress tested my mac mini with the fan at auto mode for an hour with max temps of 95 celcious, and then using mac fan ontrol speed up the fan to 5500 rpm. The temps with the stress test going on dropped to about 75 celcious. When I stopped the stress test with the fan still at 5500 rpm, the temps went down to 45 celcious in just 2 minutes. During the stress test the mac mini was reaching a boost clock speed of 2,9ghz (intel turbo boost) due to having all the cores maxed out. The screen shots are from my google drive.
https://drive.google.com/folderview?id= ... sp=sharing
tanvip99999
Steven wrote:tanvip99999
Well you can see that about 1700 ~ 2000 rpm
TBXT () - 34.5977
TC0E () - 91.9336
TC0F () - 93.7344
TCGC () - 83
TCSA () - 84
TCXC () - 93.1719
TH0A () - 42.125
TH0B () - 41.125
TH0C () - -1
TH0F () - -1
TH0R () - -1
TH0V () - 39.9102
TH0a () - 42.125
TH0b () - 41.125
TH0c () - -1
THSP () - -1
TM0P () - 53.25
TMLB () - -1
TPCD () - 72
Th1H () - 51.375
Ts0S () - 41.3477
Ts1S () - 38.3633
tanvip99999
theomoto wrote:I own a late 2012 i5 2.5ghz mac mini. I think it's about the same cpu with yours. My advice is not to worry about it. Coming from a pc, I'd say that these temps seem a bit high but now that I use Mac hardware I'd say it's normal. I stress tested my mac mini with the fan at auto mode for an hour with max temps of 95 celcious, and then using mac fan ontrol speed up the fan to 5500 rpm. The temps with the stress test going on dropped to about 75 celcious. When I stopped the stress test with the fan still at 5500 rpm, the temps went down to 45 celcious in just 2 minutes. During the stress test the mac mini was reaching a boost clock speed of 2,9ghz (intel turbo boost) due to having all the cores maxed out. The screen shots are from my google drive.
But when you stress your CPU at 95 Degree, you have to speed up the fan manualy, It's not automaticaly speeding up at Auto Mode, thats what i want to talk and ask. Is that Apple threshold temperature to speed up the fan is 90 degrees C?
theomoto
Post by theomoto »
Yes it is apple's threshold to speed up the fan when it hits 90 celcious. That happens if the temps are sustained for period of time. When I got my mac mini I was curious myself about this. The apple community forums are filled with people with the same question. But it is apple chooses to deliver a quiet operating computer without worring too much about temps. Needless to say that you have to push your mac really hard to burn its cpu and I don't know if it is possible with the thermaltrip technology that intel has. When a cpu thinks its too hot and there is a danger, slows itself down to prevent any damage.
So I would not worry too much. Since your mac is still new, go to an applestore and/or set up a meeting with a "apple genious" if you are still worried. :smile:
tanvip99999
theomoto wrote:Yes it is apple's threshold to speed up the fan when it hits 90 celcious. That happens if the temps are sustained for period of time. When I got my mac mini I was curious myself about this. The apple community forums are filled with people with the same question. But it is apple chooses to deliver a quiet operating computer without worring too much about temps. Needless to say that you have to push your mac really hard to burn its cpu and I don't know if it is possible with the thermaltrip technology that intel has. When a cpu thinks its too hot and there is a danger, slows itself down to prevent any damage.
If the apple's threshold to speed up the fan when it hits 90 celcious I wont worry about that. So well my Macbook is working normally.
That exactly my question. Thanks you very much.
Sorry about my English not really good
theomoto
Post by theomoto »
No problem, glad I could help. ;)
If you have any questions people at the support apple community are very helpful: https://discussions.apple.com :good:
