what about, when user has a txt file like :
Source_File Destination_Folder  Destination_File
Source_File must be the full name of the source file to copy (path + filename).
Destination_Folder  specifies the name of destination folder on the disc.
Destination_File  specifies the filename on the disc.
Destination_Folder  and Destination_File  will be optional parameters. Each parameter must be separated by a tabulator character.
example of file:
C:\FOLDER\SOURCE_FILE_1.XXX
C:\FOLDER\SOURCE_FILE_2.XXX       \DISCFOLDER
C:\FOLDER\SOURCE_FILE_3.XXX       \DISCFOLDER        DISC_FILE_3.XXX
+ a cmd switch which defines the ISO format (Cd/DVD/DVDDL/BLDVD), when imported files reach the media limit write 2nd/3rd ISO?
	Make ISO from filelist (?)
Re: Make ISO from filelist (?)
yota
You have to write your own parser for such text files and use AnyToISO command line
I cant see any fromfile switch, please guide me
image there is 1000files all in different directories, I can make the parser but has to be 1 ISO
maybe the solution is to provide a DLL 3 API calls?
-open
-add files/dirs (and in which ISO dir belongs) (as 1st post^)
-close
-open
-close
yota
There's sample usage on the page. You can convert 1000 files using command line, one by one.
Command line is more straightforward and cross-platform way.
sorry but I can read only
Create ISO from a local folder
the need is
the need is
example1000files all in different directories
I would like to add only 1.txt + b.txt\test\1.txt
\test\2.txt
\test2\a.txt
\test2\b.txt
yota
then you have to write your own script/app to put all the files in one folder
thats im talking about, this is how it works till today^ I would like to avoid this!
btw - I contact with Nero, there is no functionality like this
thanks anyway
thanks anyway
No problem
