MFC freezes when Macbook is running on battery
tanvip99999
Today, when I turn on my laptop, the value of MFC show on the menu bar changes every 1s, but after i use about 5 minutes, this freeze at 50 C and 1303 rmp and not change.
When I change the Mode from Auto mode to the other and return the Auto mode, every thing's ok.
What happen with my MFC, it start happen today not before?
Macs Fan Control 1.1.11, MacBookPro11,1, Mac OS X 10.9
Right Side-min{1299}curr{1303}max{6199}mode{0}
TA0P (Ambient) - 39.125
TB0T (Bottom Enclosure) - 34.6992
TB1T (Battery Point 1) - 34.5977
TB2T (Battery Point 2) - 33.2969
TBXT () - 34.6992
TC0C (CPU Core 0) - 50
TC0E () - 55.4336
TC0F () - 56.6758
TC0P (CPU Proximity) - 48.375
TC1C (CPU Core 1) - 51
TCGC () - 52
TCSA () - 51
TCXC () - 52.1406
TH0A () - 43.875
TH0B () - 42.875
TH0C () - -1
TH0F () - -1
TH0R () - -1
TH0V () - 39.3594
TH0a () - 43.875
TH0b () - 42.875
TH0c () - -1
THSP () - -1
TM0P () - 43.125
TMLB () - -1
TPCD () - 49
TW0P (Airport Card) - -1
Th1H () - 40.875
Ts0P (Left Palm Rest) - 33.125
Ts0S () - -1
Ts1S () - -1
Its always show that value and dont change
TBXT () - 34.6992
TC0E () - 55.4336
TC0F () - 56.6758
TCGC () - 52
TCSA () - 51
TCXC () - 52.1406
TH0A () - 43.875
TH0B () - 42.875
TH0C () - -1
TH0F () - -1
TH0R () - -1
TH0V () - 39.3594
TH0a () - 43.875
TH0b () - 42.875
TH0c () - -1
THSP () - -1
TM0P () - 43.125
TMLB () - -1
TPCD () - 49
Th1H () - 40.875
Ts0S () - -1
Ts1S () - -1
tanvip99999
Re: Mac Fan Contorl on my Macbook is freeze
Note I am using on battery, before i used on Power adapter. Have any differents?
tanvip99999
This is said to hear. Can you record a video illustrating the issue?
Which sensor is displayed in menubar? Did you try to change it?
tanvip99999
When I change the Mode working, it will work normaly, bua change sensor to display, nothing change not ai all.Steven wrote:tanvip99999
Or I sleep my mac and wake up, every thing is ok.
So I try with the ver MFC for win 8 on my Mac and feedback for you later with the Video if this issue still appear.
Understand me, hic sorry about my English!
tanvip99999
This problem only happen when I'm using on battery. I will show you with the video.
tanvip99999
Before I make video, I have checked it on Windows8 with MFC, I have also installed the other software name Specy to show temperature and fanspeed, it reads only not control anything. Some seconds after boot, the value on MFC and Specy is syncly, after about 10s, the MFC is freeze, value do not change while the temperature change on CPU show via Specy.
So I make video for you check it.
First I boot to the Mac OS X and the issue happen like the video.
Then I boot to Windows 8.1 to make the second video, this issue not happen @@ oh my god
So I boot to MAc Os again, the same issue and now it still happen on MacOS.
When I plug the power adapter, this issue disapears. It only in Mac OS
http://youtu.be/3y4sTQxjiuw
Try resetting the smc controller:
1)Shut down the computer.
2)Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
3)On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
4)Release all the keys and the power button at the same time.
5)Press the power button to turn on the computer.
Note: The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
Source: http://support.apple.com/kb/ht3964
tanvip99999
This is a very strange issue. Never heard of anything like that before.
Can you check system log, maybe something is there indicating the problem?
Applications -> Utilities -> Console
tanvip99999
I dont know anything when I see log file. Can you help me check it?Steven wrote:tanvip99999
The SMC value still free until the temperature rise about >60 degree C.
tanvip99999
I found this. Does it talk anything?
- Screen Shot 2014-07-04 at 12.15.51.png (93.64 KiB) Viewed 64432 times
tanvip99999
After I uninstall MFC and reset SMC on Mac (follow some people on Apple discusstion), this ERROR about SMC has gone.
I check it on window 8, MFC still freeze and make the Fanspeed in exactly one value ( Speccy and MFC both show that, but Speccy show the temperature changing, MFC not). I'm uploading the video on Window 8.
MFC just freeze until about 70 degree CPU
tanvip99999
It freezes only on batteries?
Please save complete log and upload it somewhere (zip)
tanvip99999
Yeah only on battery. When I connect the adapter it work fine immediately.Steven wrote:tanvip99999
So I will reinstall MFC and show you log file
tanvip99999
Re: MFC freezes when Macbook is running on battery
here the log file https://www.dropbox.com/s/8gryozsedexz17e/logfile.rtf
and video on windows 8.1, you should watch full video, I show you MFC freeze >> work normal when CPU rise 60~70 degree >>> Freeze again when CPU cold down.
https://www.youtube.com/watch?v=1HzjKo4UBac
tanvip99999
So it freezes on Windows as well when running on batteries?
Lots SMC errors in log indicate some problem with SMC kernel (I think)
Can you try this app to exclude problem with Macs Fan Control?
http://www.macupdate.com/app/mac/12381/ ... re-monitor
tanvip99999
it dont support my macbook pro reitna.Steven wrote:tanvip99999
tanvip99999
I also search about SMC error, so some people said that normal, nothing went wrong.
Can you read these thread and help me please?
Ps I wait for you whole day, where are you
get the day off 4th July
http://forums.macrumors.com/showthread.php?t=1736711
https://discussions.apple.com/thread/3940135?tstart=0
Try this
http://www.macupdate.com/app/mac/16609/hardware-monitor
Try this
tanvip99999
yup, MFC also freeze on windows, I have uploaded the second video to show this.Steven wrote:it freezes on Windows as well when running on batteries?
Try this
always or only on running on battery?
