dmg extraction
Ask, answer questions, and express your opinion about AnyToISO. Discussion of bugs and problems found in AnyToISO, feature requests
pat98usb
dmg extraction
Post by pat98usb »
I dont know if it is a problem of dmg or anytoiso cannot handle it or they are malformed .
If i do extract some of them are empty , on other i found others file that cannot be extracted .
"www.bearextender.com/doc/BearExtender-B037.dmg"
"www.bearextender.com/doc/BearExtender-v4.6.dmg"
"www.bearextender.com/doc/BearExtender-5.3.dmg"
Regards,
Pat
Re: dmg extraction
pat98usb
Hello!
Thank for sharing this info. AnyToISO 3.6 extracts
without a problem
BearExtender-B037.dmg is really a problem. All files are empty. Currently looking into problem
pat98usb
Re: dmg extraction
Post by pat98usb »
Hello Steven,
If i open the BearExtender-B037.dmg with Pacifist
("www.charlessoft.com") on an Apple i see:
Package Contents
Contents of Remove Old Files.pkg , 1.5 Kib
Contents of Install.pkg , 10.7 Mib
How To Properly Install.pdf , 121.1 Kib
Contents Of BearExtender-B037.dmg , 10.8 Mib
BearExtender-B037.dmg , 4.7 Mib
Resources
Remove Old Files.pkg , 37.0 Kib
Install.pkg , 4.7 Mib
Pat
Re: dmg extraction
pat98usb
Yes, it's a bug. It's currently being fixed
