now
- built-in GPU core DTS is absent in DTS list
- sensor-based value may not be hottest
I hope in the future release
+ sensor-based value=MAX(built-in GPU core, CPU core 0, CPU core 1, ...)
thanks
Missing GPU sensor on MacBookPro 13 late 2013 (ME865)
Re: Bad program logic on macbook pro 13'' late 2013(ME865)
petrov
Please post technical information from the about dialog
Macs Fan Control 1.1.11, MacBookPro11,1, Mac OS X 10.9
Right Side-min{1299}curr{1301}max{6199}mode{2,TC0C,38,75}
TA0P (Ambient) - 33.5
TB0T (Bottom Enclosure) - 29.8984
TB1T (Battery Point 1) - 29.7969
TB2T (Battery Point 2) - 28.5
TBXT () - 29.8984
TC0C (CPU Core 0) - 37
TC0E () - 37.832
TC0F () - 38.418
TC0P (CPU Proximity) - 36.25
TC1C (CPU Core 1) - 35
TCGC () - 39
TCSA () - 34
TCXC () - 38.6406
TH0A () - 33.625
TH0B () - 33.875
TH0C () - -1
TH0F () - -1
TH0R () - -1
TH0V () - 32.7891
TH0a () - 33.625
TH0b () - 33.875
TH0c () - -1
THSP () - -1
TM0P () - 34.75
TMLB () - -1
TPCD () - 35
TW0P (Airport Card) - -1
Th1H () - 32.5
Ts0P (Left Palm Rest) - 28.8125
Ts0S () - 31.0312
Ts1S () - 30.3125
TBXT () - 29.8984
TC0E () - 37.832
TC0F () - 38.418
TCGC () - 39
TCSA () - 34
TCXC () - 38.6406
TH0A () - 33.625
TH0B () - 33.875
TH0C () - -1
TH0F () - -1
TH0R () - -1
TH0V () - 32.7891
TH0a () - 33.625
TH0b () - 33.875
TH0c () - -1
THSP () - -1
TM0P () - 34.75
TMLB () - -1
TPCD () - 35
Th1H () - 32.5
Ts0S () - 31.0312
Ts1S () - 30.3125
As you can see, there's no GPU sensor supported on this macbook model.
GPU sensors are TG**
Re: Missing GPU sensor on MacBookPro 13 late 2013 (ME865)
TCGC () - 39 - PECI GPU temperature sensor
petrov
Is there any proof link that TCGC stands for GPU?
BTW "PECI" stands for Platform Environment Control Interface
first proof
experiment
3D benchmark -> TCGC > TC0C,TC1C
pure CPU load -> TCGC < TC0C,TC1C
second proof
HWMonitorProfiles.m
https://searchcode.com/codesearch/view/49834040/
[NSArray arrayWithObjects:@"TCGC", @"PECI GPU", nil],
[NSArray arrayWithObjects:@"TCGc", @"PECI GPU", nil],
experiment
second proof
HWMonitorProfiles.m
petrov
Thank you for the information. Will update it for the next release
Big thanks!
Please, do not forget, that one sensor does not provide an adequate value for the control, needed the maximum value of the group of sensors.
petrov
Please try the newest version 1.1.12.1 with PECI GPU sensor
Good job, but it's only half the problem.
