Test TjMax Temperature (max allowed CPU T) on your Mac
It's highly appreciated if you can run this simple app on your Mac:
on Windows (running Boot Camp) (RECOMMENDED)
1. Download and extract this small (100kb) ZIP file
2. Open cmd, run the following command
tjMaxTest_win.exe > output.txt
3. Paste here contents of newly created output.txt file.
on OS X (only works with SIP, System Integrity Protection off)
1. Download and extract this small (20kb) ZIP file. There should be 2 files inside (runTest and macsfancontrol.kext)
2. Open Terminal and go to this directory (runTest). After that execute the following commands:
sudo chown -R root:wheel macsfancontrol.kext
sudo kextload macsfancontrol.kext
./runTest > output.txt
sudo kextunload macsfancontrol.kext
Slash-2CPU
Re: Test TjMax Temperature on your Mac Pro
Post by Slash-2CPU »
Intel(R) Xeon(R) CPU W3690 @ 3.47GHz
MacPro5,1
ctl_id: 0x7 for ctl_name: crystalidea.macsfancontrol.kext
TjMax T: 101
Slash-2CPU
thank you.
Beschtia
Post by Beschtia »
Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz
iMac11,3
TjMax T: 99
Beschtia
Thank you!
Slash-2CPU
Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
MacBookPro9,2
TjMax T: 105
Slash-2CPU
Thank you!
In case you have problems installing the unsigned kext, this solution will help
http://www.insanelymac.com/forum/topic/ ... d-edition/
Kext_Utility.app.v2.5.7.zip
(272.03 KiB) Downloaded 18677 times
myby
Post by myby »
Intel(R) Core(TM) i5-4258U CPU @ 2.40GHz
MacBookPro11,1
TjMax T: 100
myby
Thanks!
tr0city
Post by tr0city »
Intel(R) Core(TM) i7-2620M CPU @ 2.70GHz
MacBookPro8,1
ctl_id: 0x9 for ctl_name: crystalidea.macsfancontrol.kext
TjMax T: 100
tr0city
Thanks!
timelawd
Post by timelawd »
Macmini5,2
ctl_id: 0x8 for ctl_name: crystalidea.macsfancontrol.kext
TjMax T: 100
timelawd
Thanks!
BrianK1971
Re: Test TjMax Temperature (max allowed CPU T) on your Mac
Post by BrianK1971 »
Intel(R) Core(TM) i7-2720QM CPU @ 2.20GHz
MacBookPro8,2
TjMax T: 100
BrianK1971
Thanks!
houdini
Post by houdini »
Intel(R) Core(TM) i7-3615QM CPU @ 2.30GHz
Macmini6,2
TjMax T: 105
houdini
thank you!
hyperbolical
Post by hyperbolical »
hi, i am unable to run the test, terminal comes back and says illegal. macbook pro 2009. any advice?
my fans started running noisy just today. CPU Diode is 163.4F Left fan is 3870 rpm, right side 4181. i haven't changed fan speed yet until i find out whether its due to temp.
i have activity monitor running, nothing using up alot of cpu.
recently repaired permissions and freed up 100gb of free space on machine.
is there a manual or instructions for this app???
thanks for any help
azsx
Post by azsx »
MacBookPro8,2
ctl_id: 0xc for ctl_name: crystalidea.macsfancontrol.kext
TjMax T: 100
