Download
What's new in 3.0 Release:
Main:
- Install Tracker - install and trace programs. 100% clean removal afterwards!
- Revised and improved User Interface (including new icons)
- Secondary toolbar with addional functions (can be hidden)
- Adjustable positions of toolbars (top/bottom/side)
- Simplified and more convenient use of task panel (in the left of Uninstaller and Startup managers), added keyboard navigation for task panel controls
- Automatic check for updates (optional) and new version dialog with 'what's new' list
- Improved preferences dialog
- New HTML report (both for Uninstaller and Startup manager)
- Run different Windows Tools (Tools menu)
- Program preferences are always saved to the 'preferences.xml' file (located in CSIDL_APPDATA\CrystalIdea Software\Uninstall Tool)
- New Preferences dialog
- 90% of program code is rewritten/reviewed/optimized
- Improved program stability
Uninstaller:
- Uninstall Wizard: faster scanning
- Uninstall Wizard: detection of running processes among found traces; termination on request
- Uninstall Wizard: informs and removes (on next system reboot) files that are in use by the system
- Better program listing, better icon detection
- Ability to force stop uninstall processes (when third-party uninstaller is freezed)
- Show recent items in the secondary toolbar (not in status bar) with grouping items (Apps/System/Hidden) in a popup menu
- Improved cache algorithms
- Improved search filter usage
- List view with small icons looks better now
- Google for program name (Ctrl+G) and its publisher (see 'Action' menu)
- Uninstaller cache is now saved to 'CachedData.dat' file (located in CSIDL_APPDATA\CrystalIdea Software\Uninstall Tool). One can manually refresh the cache by simply pressing the Refresh button in the toolbar (F5)
- Numerious improvements and small fixes
Startup:
- Multiple items selection
- Company column to display item's publisher/author
- Google for program name (Ctrl+G), .exe name and publisher (see 'Action' menu)
- Better way of handling situation when there're no items in the list
Screenshots:
Uninstaller:
Startup Manager:
