Uninstall Tool 3.0 Beta
Re: Uninstall Tool 3.0 Beta
Rafel
Maybe try to reboot first?
I did a lot of reboots .
I'll do the next steps:
- Make a system restore image with Acronis.
- Do a clean OS install and test.
-Restore previous image with acronis.
Our man once seen
We are not looking for simple ways:)
I did the steps and UT runing without problems.
It isn't UT.
It isn't UT.
Rafel
great! It could be a problem to release 3.0
Don't worry. UT runs perfect
thank you, that sounds great. We have no issues to solve, so release is about to be done.
PS. 12 November seems to be a good date, Uninstall Tool 2.0 was released 12 November 2006.
UT 1.0:
UT 2.0:
UT 1.0:
UT 2.0:
Very niceeee. Waiting very impatient.
wait wait wait
I have not seen the first version UT
are not accustomed to see it like this
but one thing is immediately clear. progress in the face
So far all is well, +50 random installations in virtual machine with no issuesSteven wrote:Hi, dear users!
What do you all think
- Is current Install Tracker useful/functional/interesting?
- Is beta version ready to become final?
D.Y
Thank you very much, sir. Tomorrow the beta will be release without modifications.
Catalan translation is welcome, can be added at any time.
plans to release does not change?
is already not want the beta version .smile.
Trashe1
I don't understand.
after using automatic translation 50% of your messages are not understandable.
I don't understand.
after an automatic translator myself sometimes wonder what I am writing "smile"
I asked, "plan to release November 12 program has not changed?"
really want to upgrade
I'm translating to catalan. Sorry for the delay, i have had a lot of job.
Rafel
No problem, it can be added at any time.
Trashe1
Trashe1
noticed another strange feature. if you run tools - system tools - windows componets.
we can see
but if you open tools - system tools--add/remove programm
and run the add / remove windows componets
we see
I think it's a small bug
we can see
we see
Trashe1
Thanks, reproduced on X64 Windows 7.
that error is found?
after upgrading from 5202 to 5206 version of the Start bar there is another label on UT
the example below
the example below
