I'm getting CPU utilisation of about 4-15% on version 1.1.12.2. To put that into perspective, I have a quad core machine at 2.2ghz with HT and all other idle processes use less than this.
Is this to be expected? It seems very high.
High CPU usage as of latest version
Re: High CPU usage as of latest version
azsx
Please update your post with this (http://forums.crystalidea.com/viewtopic.php?f=11&t=1006)
and
post screenshot of System Monitor that shows MFC is eating 4-5% of CPU
and
Sorry about the screenshot, I had one ready and then forgot to post it.
I have since discovered that one of my HDDs was corrupt and the CPU consumption has dropped to a more reasonable <3% after repairing the partition. I don't know if that is normal or not if this is related but I'm satisfied with that. Please disregard my original post, sorry for the bother.
It must normally be < 1%
See CPU column not CPU Time
<1% would be fine. I had larger numbers to, but its ok. My Mac has a longer life
- That’s from activity monitor
- MacFans CPU.jpg (104.62 KiB) Viewed 17806 times
MacPro 5.1 OSX 10.9.5
CPU usage will be improved in 2.0 version.
