Features Request
tanvip99999
Features Request
I think you should add the White label in the status bar on next update. Because when I use the status bar with the Dark color tone (You can change it in System Preferences/General on OS 10.10), I can not see any infomation from MFC on the status bar. Thank you so much, best app I have used for Fan controling
- Screen Shot 2015-01-21 at 00.10.47.png (91.58 KiB) Viewed 7113 times
Re: Features Request
tanvip99999
Actually it's done in 1.2 beta 3, which will be available soon
